DNS settings question for Mark, Corrosive, BirdDog, or whoever else might be able to help...
infinitytecwrote:
Maybe put the NetGear one on auto and change the modem.That's what I was thinking, but I wasn't quite sure.
I could just try it either way. It's not like it's an experiment that would hurt anything. Well, just my luck... J/K. :p
Depends on how many devices you want to automatically use it.
If you want to change everything at once, change it as far forward as possible, i.e., the modem.
Just remember it affects how the Meter works, since it will now need the IP of the modem gateway (192.168.0.1) to work.
I should note that the main reason for me asking this is that Google's DNS tends to be more stable for me. Using HughesNet's I sometimes have problems, especially with Amazon.com.
It was primarily for my phone. I have four devices.
1: The desktop I am on now, which is what I mostly use and normally have set to Google's DNS on its own.
2: A laptop that is connected, perhaps, twice a month, primarily to keep it up to date and save a system image (once per month).
3: A notebook that is connected once per month, max, and that's only to keep it up to date and to save a system image.
4: A phone that's connected about every other day, mostly to keep the programs up to date, but sometimes to use after I've shut my desktop down.
The desktop, laptop and notebook I can set to Google's DNS in their network adapters (the desktop normally is, as mentioned). Again, it was primarily for the phone, and to make things a little easier. But, if it's going to screw up the Usage Meter, it's not worth it.
If I set the Netgear router to Google's DNS, will it cause the four things connected to use Google's DNS without causing any issues with the Usage Meter? Basically, all adapters and the HT2000W set to automatic, but the Netgear router set to Google's DNS. All four devices utilize the Netgear router.
