Domain block w/wifi but not hotspot
Starting in Febuary 24 one of my buisness information sytems became unloginable with HN wifi, i can log in using my ph hotspot on same device, durring the whole month of april it worked perfectly then again became unloginable. i get err_connection_reset. very fustrating. i am not puter savy so i am at my wits end which isnt much. thank you
Six60street,
Thank you for reaching out! Welcome to the Community! We're sorry to hear you've been experiencing service issues. I was able to pull your account up through your Community profile, which is great! Upon investigating your account, it seems you've been having frequent modem related state codes. To start, I'd like to send a replacement modem, to see if that alleviates the issue. Please expect the replacement soon; you can use its box to return the old modem. For your convenience, the return label is included in the outer pouch.
Let me know how the new modem works out for you!
Thanks,Remy
Try clearing the cache, history, and cookies. If that doesn't fix the problem, try clearing the DNS by following the procedure below:
1. Turn off all of the devices that are using the modem (all phones, iPads, computers, etc.)
2. Unplug the modem's power from the wall socket.
3. Wait a minute, then plug the modem back in.
4. Wait about 5 minutes after all the lights on the modem are back on, then turn all your devices on one-by-one.- Six60streetFreshman
Did not work, im at my wits end.........
Did you try both things?
Other things you could try:
Use a different browser
Use incognito mode
Are you using a VPN? Turn it off.
If you have an ad blocker, turn it off
Turn off all add-ons
Edit: See this too: https://www.pcguide.com/how-to/err_connection_reset/
ok i will try it thanks
- MarkJFineProfessor
Pay particular attention to the part in step 1 where it said: All the devices using the modem. If there's a corrupt DNS entry hiding somewhere in your house, and it's on that device when the modem comes back up, it may re-insert it back into the system without you knowing it making the whole thing a waste of time.
- 6 months ago
- 7 months ago
