macsretandme
8 years agoNew Poster
My problem is that about 5 days ago, out of the blue, my internet connection started dropping connections to the gateway. Based on the gateway address I believe it's out of Salt Lake City. I've veri...
Good morning macsretandme,
Edit:
macsretandme
Did not mean to offend earlier, just extremely frustrated.
GabeU wrote:
macsretandme wrote:there my acct # is taken off the images. now can i get some help?
You go out of your way to help keep someone safe on the net and what do you get? You get snark. SMH.
That's understandable.
