Good morning macsretandme,
Edit:
the "cycling" I'm referring to seems to be a pattern of connection/association with the server in Salt Lake City. Connection performance will be absolutely fine, start declining, out altogether, then suddenly restored all in the same web browsing session and repeating the problem pattern about 10 - 15 minutes after continuing browsing. Almost like a looping effect. Everything I can think to test on this end with equipment checks out fine. Running windows 7, Firefox Browser 57, Netgear wireless router, all operating normal, even when eliminating router, the problem persists. My modem is an HT1100 Gen4, not ready to commit to Gen5 w/2 yr contract. Disconnecting the modem from the power/computer and starting fresh does not correct the problem.
Thank you for the clarification, I will include this in my escalation report. Once I have an update for you I will post back.
- macsretandme9 years agoNew Poster
I don't know how. I don't know why. Nothing done but browsing on this end, but this morning and now my connection/association state is running smoothly and without a problem. Did someone on your end do something? If so, can't thank you enough. Please feel free to pull whatever info you need from my acct./system. If it starts up again, I'll contact you.
- Liz9 years agoModerator
Hmm that sounds good, I haven't heard back from engineering after I sent the escalation. Let's keep an eye on the performance, and keep me informed on how it goes this weekend. If all continues to go well I can let engineering know.
Update of weekend connection. So far so good still. Good connections no acceleration errors no gateway problems. I guess if it starts up again I will contact you again. Thank you for your attention on this. Again please feel free to pull any info needed from my account to help if needed for others with the same problem. Merry Christmas.
Edit:
