Good morning macsretandme,
Edit:
I don't know how. I don't know why. Nothing done but browsing on this end, but this morning and now my connection/association state is running smoothly and without a problem. Did someone on your end do something? If so, can't thank you enough. Please feel free to pull whatever info you need from my acct./system. If it starts up again, I'll contact you.
Hmm that sounds good, I haven't heard back from engineering after I sent the escalation. Let's keep an eye on the performance, and keep me informed on how it goes this weekend. If all continues to go well I can let engineering know.
- macsretandme8 years agoNew Poster
Update of weekend connection. So far so good still. Good connections no acceleration errors no gateway problems. I guess if it starts up again I will contact you again. Thank you for your attention on this. Again please feel free to pull any info needed from my account to help if needed for others with the same problem. Merry Christmas.
- Liz8 years agoModerator
Edit:
