Gwalk900, GabeU, BirdDog, C0RR0SIVE, MarkJFine, I'm sure this is a stupid question, but, does an extender work with the 5GHz broadband??
From what I've read I believe so, but it all depends on the extender. Plus, I imagine that while utilizing an extender with the 5Ghz band it would still be short in range, like the source 5Ghz signal.
Edit: BirdDog posted while I was typing. I defer to him.
- 5 months ago
