maratsade wrote:Gwalk900, GabeU, BirdDog, C0RR0SIVE, MarkJFine, I'm sure this is a stupid question, but, does an extender work with the 5GHz broadband??
Sure, but like anything, not good to go with the cheapest available and do some research. Depends how far and how fast you wnat to go.
https://www.tomsguide.com/us/best-wifi-extenders,review-2225.html
- 5 months ago
