That did it!!! Just making them couple changes to the 2.4 channel fixed the speed differance between the two. Thanks everyone!
Not that I need it now since I have great coverage on 2.4 and my speeds back my external router which is an older frontier (actiontech mi424) still dont work well plugged into the ht2000. Just curious, might want to expand coverage someday and buy a decent router but wouldnt want to do that if the ht2000 dont like things plugged into it.
