Wow... I'm terribly sorry.
I wonder if your computer couldn't do 11n?
Also, in general, sometimes rebooting the wifi by itself will stabilize it, then sometimes you need to reboot the whole modem and wait until the wifi section settles.
I rebooted everything several times -- no dice. :(
