Changing the settings killed the network and I couldn't access the internet at all. Changing the settings back made my access spotty -- it cuts off every few seconds and has to be reconnected manually. Not sure how to fix it since the settings are back to what they were. Weird.
MarkJFine wrote:Whoops... Sorry about that. Wonder what happened.
maratsade wrote:Changing the settings killed the network and I couldn't access the internet at all. Changing the settings back made my access spotty -- it cuts off every few seconds and has to be reconnected manually. Not sure how to fix it since the settings are back to what they were. Weird.
Was it with the 5Ghz WiFi you made adjustments, or the 2.4Ghz WiFi? Either way, I hope it soon gets back to normal for you.
Strange that it would now be doing that, especially since nothing was changed on the computer itself.
