Lower quality connection (HT1100)
Hi Hecubus,
In order for the reps to be able to help with speed issues they will need some speed tests to be performed. Though they can see certain things from their end, they can't see everything you can, and the test results will not only give them an idea of your speeds, but also what could be causing the issue. The protocol for the speed tests are as follows...
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform 3-5 tests during different parts of the day, then share the account results link with us here.
-use the manual 12MB size download test file
-If testing upload instead of download, please use the manual 4MB size upload test file
The Reps are on M-F from approximately 8AM to 5PM Eastern. They will be the ones to address your speed issues, but they will need these tests to do so. - 8 years ago
Well I think they did use "the little man" ie wizard to get me to relay numbers. I wonder if it's cultural or if they weren't supposed to call it a wizard. I'll call it solved since weather is an issue now and I'm too busy with work. I meant no disrespect to online reps. I've just never had a complicated issue to fix.
Wow, I'm guessing calling is similar. Old HughesNet was far simpler..I don't have a good PC to test. Considering the day calling will be better. Getting a new phone line is costly but DSL is way less trouble. If calling doesn't help anyway.
Well, you're certainly free to call if you like. Their number is 866-347-3292. BTW, "old HughesNet" required speed testing for speed issues, as well.
They may still run remote diagnostics on your HughesNet equipment to see if anything is amiss. Make sure to leave your HughesNet modem plugged in so that they can do so (which may not be until Monday).
As intimated in the previous post, the reps aren't normally on during the weekends, so it's likely you will not hear anything from them until at least Monday.
- Hecubus8 years agoFreshman
They mentioned speedtests but they never actually needed them.
Hecubus wrote:They mentioned speedtests but they never actually needed them.
The only time speed tests were not required was when phone reps could quickly/easily see a specific problem with HughesNet equipment or the system. The vast majority of the time this was not the case, and speed tests were required, as were "responsiveness" tests, for a time.
As stated, you're free to call them, or you can wait until Monday to see if they can see anything amiss with the equipment or system. If not, they'll require speed tests.
