Helene
17 hours agoNew Poster
Need to switch to 2.4 GHz
M security system requires connection to 2.4 GHz band. Is there a way to split the bands to choose which devices can connect to one or the other? (5 vs. 2.4)
1 Reply
- MarkJFineProfessor
If the system only uses 2.4 it's likely that it won't even see the 5 GHz connection. Therefore, what's listed should only be the 2.4 connection. You should be able to choose what's listed and be ok.
