Tubaugh
8 years agoNew Poster
No connectivity/ no help
I lost all connectivity earlier this afternoon while power cycling my router. Once the router came up the only lights are the power and WiFi. All the rest are dark. Called technical service and began ...
Hi Tubaugh,
I see it's your first post here, so welcome to the community! I pulled up your account to start addressing your concerns, but I see that you've already gotten back in touch with us and got a complimentary dispatch set up for tomorrow. Hope it goes well!
infinitytec
8 years agoJunior
You're in the right place!
Try making sure the cable attached to the back of your modem is screwed on finger tight. That will ensure optimal connection to the dish.
I will tag some reps so they can help:
Hal
Hal
