Problem AGAIN with speed in evening!
bkeeper -our last discussion ended with upgrade and cancellation options. I have private messaged you about upgrading and what I can do for you.
Hi:
Seems like you're the only one that is not ignoring me - that has been the most irritating and upsetting part of this whole mess. The moderators/techs act as if they just hope the problem will go away if they don't do anything. Even just a note once a week to say they are still on the job would help.
I recognize the problem and am still wishing and hoping.
Would like to go to Gen5 -- but can't afford the extra (average over the next two years) almost $500 per year. AND how do I know the problem wont resurface with Gen5? The fine print still reads the same. I kept my end of the bargain and payed for the service every month. What about Hughes?
At least this last week was slightly better - most (not all) of the time I was able to stream Netflix with little or no buffering -- But, in the evening - don't try anything else! Most of the time the speed stayed above 1.0 Mbps, didn't drop into the Kbps. Just barely enough to stream Netflix and not much else. Still VERY slow, not what I signed up for years ago. Daytime speed had a definite improvement.
Will let you know what happens next week.
Thanks
bkeeper,
What plan and modem do you have now? How much are you paying now? Did you call HughesNet to find out if they can give you a deal?
I called them and got a really good deal as far as the new modem for Gen5. I am on the 20/50 plan which is $49.99 for the first year. After that it goes to $69.99. My plan under Gen4 was $79.99 for 15/50.
It is clear that your speed is not going to change for quite a while.
