MODEM
MODEM
MODEM
MODEM
I do this multiple times every day! Often, when it drops a call, I start getting a ringback, as though the system were trying to reestablish the connection. When I pick up, the line is dead. As soon as I hang up, it rings again. The only way to stop this is to cycle the ATA. Sometimes, I cycle both, but getting everyone out of what they're doing and off the internet is a bit more hassle.
In any case, that has not helped yet. Once it has started dropping calls, the chances of making another call of more than 2 minutes or so diminish dramatically. Cycling the sysytem fully or partially does not seem to change that.
I hope I can get some response soon. For obvious reasons, I can't *call* customer service on the VOIP. We are in a rural area with no cell phone service.
(To be fair, the only wired phone provider in this region is Frontier, and their products, pricing, and service are terrible!)
HELP! Please!
- Liz7 years agoModerator
Hi DocT,
Haven't heard back from the team yet, but I will follow up again Monday morning.
- DocT7 years agoFreshman
MODEM
MODEM
MODEM
MODEM
Epilogue.
Angela (customer service rep from the chat conversation) called me this morning to ask if the problem had resolved. I told her it had.
So good job to HughesNet customer service for fixing the problem, and again for followup.
I'm impressed.
t
- Robp17 years agoJuniorI completely understand your frustration and Frontier is our only alternative here as well. Networking called me back today and I would recommend that you be blunt and make sure that you tell them they have to call you back. It is more than frustrating because of the drops in service, but the team is finally helping. By chance have you tried a corded phone when you attempt to make a call? Sometimes the frequency of the wireless handset can mess with the HT2000w modem. I hope they get it fixed for you soon.
- 10 months ago
- 2 months ago
