MODEM
MODEM
MODEM
MODEM
Hi DocT,
Haven't heard back from the team yet, but I will follow up again Monday morning.
MODEM
MODEM
MODEM
MODEM
MODEM
- DocT8 years agoFreshman
Epilogue.
Angela (customer service rep from the chat conversation) called me this morning to ask if the problem had resolved. I told her it had.
So good job to HughesNet customer service for fixing the problem, and again for followup.
I'm impressed.
t
- Liz8 years agoModerator
Good morning DocT,
Thank you for this wonderful update, I'm glad Angela helped resolve your concerns. Curious, which instructions did you follow to hook up your ATA? Here are two PDFs, one for each Innomedia ATA model:
http://voice.hughesnet.com/activate/docs/innoQuickStart.pdf
http://voice.hughesnet.com/activation/docs/mini.pdf
Any feedback or concerns about the setup instructions are much appreciated. Thanks!
This is a great reminder to me double-check the basics with the customer, even if they say they've done it already. XD
I'm getting a "directory not found" on the second link.
In any case, I didn't really follow those directions (although having that document around would have been useful last week). We signed up through a local distributor in Houghton Lake, MI and they did the installation. Our previous system (Exede) had a modem with only one LAN port, so carrying the internet signal through the ATA to other devices was the only way to go.
The directions on the first link look fine to me, and quite clear. Perhaps our local distributors need a refresher!
t
Wow! ok good to know! Thank you! Glad it's all sorted out now. Feel free to drop by again if you need anything else.
Have a good rest of your week!
- Robp18 years agoJuniorThe last call to HughesNet was a bit heated as they still had not fixed anything. Finally a rep from account management looked through all the problems, and had a tech out to my house in less than 48 hours. Clayton was excellent, he had the problem diagnosed and fixed in two hours. The original install on the dish was done incorrectly, the ground wire was faulty, the dish was all over the place, and the coaxial wire wasn’t installed correctly. Clayton made sure everything was in place, realigned, and up to 100% before he left. It’s been a few days MY PHONE HAS NOT DROPPED A CALL and my internet is WORKING! A big shout out to the The team, I really can not thank everyone enough!
- Jay8 years agoModerator
Robp1,
Thanks for the update! We're glad to hear that your issue has been resolved and that you had such a great experience!
Thank you,
Jay
