Hi rossalissalove,
Thank you for your patience while your case was worked. I pulled up your account and I see that Wade has already issued a dispatch to replace the radio and modem. Your Dispatch is currently scheduled for Thursday, Jun 28, 2018 between 02:00 PM-05:00 PM. I'll privately message you your local tech's contact info so that you can coordinate if that time does not work out for you.
Hi Ross, Welcome to the community! I have located your account and have begun running diagnostics on your equipment, and currently everything looks good. With regards to the 12.1.9 state code, the quality of the power source can cause intermittent connectivity and that state code. Is the HughesNet plugged into a surge protector? Temporarily plug the modem into a wall outlet and see if the 12.1.9 and disconnects go away.
-Wade
