Good morning macsretandme,
Edit:
If you know how, you shoud edit your SAN out of those pictures. That's the number that starts with DSS. That's your account number, and it's sensitive info, like your phone number or address. You should never post your SAN on a public site.
You can edit the SAN out using Paint.
yes I realize that, should've done that. But you haven't addressed my issue!
macsretandme wrote:yes I realize that, should've done that. But you haven't addressed my issue!
This isn't instant messaging, nor chat. The reps can often take up to 48 hours or more to reply to an issue. The reps are on M-F from approximately 8AM to 5PM EST. Liz Amanda
As for your SAN, whether you edit it out of your pictures, or delete the pictures that contain them altogether, is your choice. I was simply trying to save you from a possible future headache in the form of identity theft. After all, again, that is your account number.
- macsretandme9 years agoNew Poster
there my acct # is taken off the images. now can i get some help?
- Liz9 years agoModerator
Hi macsretandme,
Welcome to the community and thank you for posting and sharing your screenshots, these help. I ran diagnostics on your site and currently all shows well with the HughesNet equipment.
When you said "it came back absolutely fine until the next "cycling"???" does that mean you power cycled your modem to regain connectivity? If not, does power cycling the modem make a difference? What I mean is to disconnect the modem's power cord from its power brick for half a minute before reconnecting. Please let me know if the disconnects persist after that.
I will escalate your case to engineering in the meantime and post back once I have any additional instructions or updates for you.
