Aedan wrote:
HT1000 or HT1100? If you are on the 1000, then Hughes will be sending you an HT1100 or HT2000w to replace it... The HT1000 units had been phased out for being very problematic.
If it's an HT1100 then either the coax isn't in great shape, or your ODU is potentially flaky.
Again, the modem that I have is an HT1000 modem.
Had to make sure... It's rare to see someone with a 1000 series unit anymore.
Monday, either Amanda, Liz, or Aedan will create an order to send you a newer model modem... After that is installed then if the issue persists they can run remote diagnostics.- GabeU9 years agoDistinguished Professor IV
C0RR0SIVE wrote:
After that is installed then if the issue persists they can run remote diagnostics.They won't run the diagnostics until the modem's replaced?
They might, but the diagnostic information the HT1000 provides and collects is limited compared to the HT1100 and HT2000.
- 10 years ago
