Aedan wrote:
Ah. I didn't know that. Still, though, it wouldn't hurt to leave it powered, just in case they can get enough info to tell what's wrong (if it's not the modem, itself). It might kill two birds with one stone.
Will a technician come and replace the modem that we're currently currently using with a newer one? I just want to make sure on this.
- 10 years ago
