Aedan wrote:
Hello arceus213,
Thank you for the prompt response. We have sent you a free replacement modem (HT1100). Please look out for it in a couple days. Thanks.
So we had got the modem either Tuesday or Wednesday. All was fine most of the week, until the low signal issue happened again a little bit ago. The only difference is that it occured for almost an hour.
This was the downlink state code before it changed to 11.2.1 as shown in this picture:
The uplink state code was 12.2.1. I had reset the modem to see if the problem was solved, but it still occured as shown in this picture:
The current diagnostic code is 0000-0000-0000-0027.
P.S. Forgot to say that the Modem's serial number is B3 0010751134 A3.
- arceus2139 years agoSophomore
Okay.
This is what I saw. Note that the signal strength went to the exact same level. This was after resetting the modem in an attempt to fix it, which explains the low packet count. I made sure to capture it just in case....
- Aedan9 years agoSenior
Ah. Okay. Thank you. I figured it was something technical, as when it's been out due to a storm over the years it's acted a bit differently, with the signal strength being all over the place, and the system pretty much working immediately after that signal was back up to "strong enough", but not this time. Plus, I know that my gateway is in Roseburg, OR, and there was nothing going on anywhere around there at the time.
Oh, wait. Can I get a three cent offset for the month, due to it being down for a half hour? J/K!!! :p
- 10 years ago
