Transmit / Uplink Problem
David,
Remy
There used to be a map of the older sat's beams.
maratsade wrote:There used to be a map of the older sat's beams.
SatBeams has the beam footprints for all of HughesNet's current sats, I believe. This includes the now corrected footprints for the ES19, as well as those for the ES17 and Spaceway 3 satellites. I'm not sure about the older ones that they leased capacity from, however. Granted, they don't have maps that show all of the beams at the same time like the one you're referring to, but you can see the footprint of each beam individually.
I've tried using SatBeams but can't figure out how. Herp derp.
