Good morning everyone,
Thank you,
Okay, I decided to throw everything at it at once. I unplugged the modem, router, and dish. I shutdown and restarted the laptop. I connected the modem directly to the laptop and turned everything back on. I reset the MBX, turned off web acceleration, disabled windows anti virus and windows firewall for both public and private networks. I then cleared my cache and cookies and loaded amazon.com with control-shift for full refresh.
Viola! It worked.
I've turned the router back on, went back to wireless, turned on my anti virus and firewall, and turned web accelaration back on. Amazon.com is loading properly!
No idea what happened there.
For completeness, here is my current trace from my wireless laptop, now that everything is working:
Thank you for your help.
