Aedan wrote:
Did you happen to write down the state code on the System Status page when it was down? Did you see that your signal strength had surely dropped? If so, do you remember what it was, or what it was approximately?
Do you know where your Gateway is? If you look on the System Status page, where it says IP Gateway Association State, what are the three letters after the J1 or J2? Don't list the whole thing, only the three letters after the J1 or J2.
BTW, the reps are on M-F from approximately 8AM to 5PM EST, so it won't be until Monday before a rep on here will be able to take a look and, chances are, run remote diagnostics on your modem/system.
Unfortunately, I didn't write down the state code at the time. I can however, show the state code monitor in the following pictures:
Nevermind the 30.2.2 state code. The reason it's there is because I have problems downloading from sites such as Mediafire when web acceleration is enabled, so I keep it disabled. And the outage wasn't too long, although I forgot how much time it was approximately for. Currently the signal is back to normal as shown in this picture:
This is the current association status (mine didn't have J1 or J2):
Finally, the diagnostic code changed, it is now 0000-0000-0216-3842, in case you wanted to know.
WOW.
What modem do you have? Is it an HN9000S?
The Gateway query was for the possibility that there were storms wherever your Gateway is located. I don't have any idea if that's what's been causing your problems, but only that storms can.
I wonder if maybe one of your fittings outside is getting moisture inside of it, and it's only happening during the nighttime hours due to that being when condensation would occur. I know that has happened to people.
Perhaps someone who is more familiar with what's going on with those state codes might have an idea. From what I'm seeing, it looks like they are related to connection issues, but I can't say for sure.
I'll tag the reps so they'll be sure to see this on Monday.
- arceus2139 years agoSophomore
The modem that I have is an HT1000 modem.
HT1000 or HT1100? If you are on the 1000, then Hughes will be sending you an HT1100 or HT2000w to replace it... The HT1000 units had been phased out for being very problematic.
If it's an HT1100 then either the coax isn't in great shape, or your ODU is potentially flaky.
