Aedan wrote:
Unfortunately, I didn't write down the state code at the time. I can however, show the state code monitor in the following pictures:
Nevermind the 30.2.2 state code. The reason it's there is because I have problems downloading from sites such as Mediafire when web acceleration is enabled, so I keep it disabled. And the outage wasn't too long, although I forgot how much time it was approximately for. Currently the signal is back to normal as shown in this picture:
This is the current association status (mine didn't have J1 or J2):
Finally, the diagnostic code changed, it is now 0000-0000-0216-3842, in case you wanted to know.
WOW.
What modem do you have? Is it an HN9000S?
The Gateway query was for the possibility that there were storms wherever your Gateway is located. I don't have any idea if that's what's been causing your problems, but only that storms can.
I wonder if maybe one of your fittings outside is getting moisture inside of it, and it's only happening during the nighttime hours due to that being when condensation would occur. I know that has happened to people.
Perhaps someone who is more familiar with what's going on with those state codes might have an idea. From what I'm seeing, it looks like they are related to connection issues, but I can't say for sure.
I'll tag the reps so they'll be sure to see this on Monday.
- arceus2139 years agoSophomore
The modem that I have is an HT1000 modem.
HT1000 or HT1100? If you are on the 1000, then Hughes will be sending you an HT1100 or HT2000w to replace it... The HT1000 units had been phased out for being very problematic.
If it's an HT1100 then either the coax isn't in great shape, or your ODU is potentially flaky.- arceus2139 years agoSophomore
Again, the modem that I have is an HT1000 modem.
