Aedan wrote:
Hello arceus213,
Thank you for the prompt response. We have sent you a free replacement modem (HT1100). Please look out for it in a couple days. Thanks.
So we had got the modem either Tuesday or Wednesday. All was fine most of the week, until the low signal issue happened again a little bit ago. The only difference is that it occured for almost an hour.
This was the downlink state code before it changed to 11.2.1 as shown in this picture:
The uplink state code was 12.2.1. I had reset the modem to see if the problem was solved, but it still occured as shown in this picture:
The current diagnostic code is 0000-0000-0000-0027.
P.S. Forgot to say that the Modem's serial number is B3 0010751134 A3.
- 10 years ago
