Kafka
8 years agoSophomore
Signal Strength fade, now no connection
Hello. I need some assistance. My signal strength has been rapidly falling over the last couple months. After installation last summer, it was up around the mid 80's and everything worked OK....
- 8 years agoThe Timeless technician has appeared and has fixed the problem(s). The Timeless technician was on time, was of a professional demeanor, and was well-equipped with an impressive array of tools on an awesome web-harness toolbelt that may have included a hovercraft function. Otherwise, he used my not-very-good ladder to get to the dish. Yay. The Timeless Communications technician deserves a gold star. I was impressed. Thanks, Liz
Kafka
Great.
I await email from the technician.
Thanks again, Liz.
Kafka
Still waiting for email...
You may want to call Timeless Communications yourself -- would save time.
The name is a bit ironic...
- Liz8 years agoModerator
Hi Kafka,
I followed up on the dispatch notes and it looks like they tried emailing you at the email address you specified to me on July 25. Are you able to receive emails in general on that address? I'll see if I can get an email address for Timeless that you can use.
