Kafka's avatar
Kafka
8 years ago
Solved
Signal Strength fade, now no connection
Hello. I need some assistance.   My signal strength has been rapidly falling over the last couple months.   After installation last summer, it was up around the mid 80's and everything worked OK....
  • Kafka's avatar
    Kafka
    7 years ago
    The Timeless technician has appeared and has fixed the problem(s). The Timeless technician was on time, was of a professional demeanor, and was well-equipped with an impressive array of tools on an awesome web-harness toolbelt that may have included a hovercraft function. Otherwise, he used my not-very-good ladder to get to the dish. Yay. The Timeless Communications technician deserves a gold star. I was impressed. Thanks, Liz
