Slow GEN 5 using my LAN
I finally have the solution to the problem...without knowing the exact problem! Here is what I did, which fixed the problem.
In the little Cortana search box in the lower left corner of my Windows 10 desktop screen, I typed in "Network Reset" (without the quotes).
A new window opened, and I clicked on the "Reset Now" button.
The computer needed to be restarted manually, even though the screen said it would restart automatically. So, I manually restarted the computer, brought up the www.testmy.net website, performed a manual 25Mbps speed test, and I'm back up and running at 25Mbps+ again.
Problem Solved.
Hi Gabe, thanks for the suggestion. So, I have a brand new Cat 5/6 cable and replaced my existing cable with the new one, as you suggested. The problem didn't get resolved. When I plug my laptop in to one of the LAN ports on the back of the router/modem, I get 25Mbps+. When I plug my desktop computer in on a different port (or the same port as my laptop), it gets 7Mbps. A couple weeks ago, Hughesnet sent me a brand new router/modem. At the time I replaced it, I was getting 25Mbps on my desktop computer. Just in the last few days the speed dropped, but only on the desktop computer. Not on other computers. I'm wondering if Windows 10 did an update and changed some sort of setting?
They did just have an update to fix something that even scared NSA.
MarkJFine wrote:They did just have an update to fix something that even scared NSA.
If I remember correctly, it was actually the NSA that notified Microsoft, and if they're concerned more with users' security than exploiting the issue for their own purposes you know it's bad.
