State Code 12.1.12 -- A transmit problem has occurred
The diagnostics code you have provided is not meant for the use of remote troubleshooting. Your state code, which would be in the format of 0.0.0, is what we require. It appears the equipment has maintained a fully operational state code since the issue was corrected. If the state code changes and you are experiencing an issue with the service at that time, please let me know.
-Damian
-Damian
Thank you for your help - I very much appreciaiate it! I depend on Hughesnet as I am able to work from home. In two years I have been very happy with the service. Thank you!
