State code 12.9.1 a transmit problem has occurred
Hi Hoxness,
Thank you for the information. I am making some adjustments to your modem to re-associate itself with our network and establish some higher operating baselines. Hopefully this will kick your system into gear. The signal looks fine, maybe a little drop in strength but nothing that would cause issues you are seeing. The modem may reboot a couple of times, but will eventually become steady. Please attempt to use the internet at some point today and let me know how the experience is.
Hi Hoxness88
Welcome to our community and thank you for your post. I've located your account and will run diagnostics to see if I can find the problem. Are you missing any lights on the front of your modem? Also, please be sure there are no obstructions in the dish line of sight. I will return soon with the results and let you know if there is any troubleshooting I need you to do.
Thank you,
