prsmart
8 years agoSophomore
System light blinking
We had a close lightning strike yesterday evening, and since then my HT1100 modem ONLY has the system light blinking. No other lights are on. Any assistance would be appreciated.
C0RR0SIVE
8 years agoAssociate Professor
Have you attempted to reboot your terminal since then? How close was the strike? ODU could be fried if close enough...
