System light blinking
Thanks for checking, prsmart. I've sent another HT1100 to you, so please expect that to arrive this week. Let me know how the replacement modem works out for you.
- Liz9 years agoModerator
- prsmart9 years agoSophomore
Sorry for the delay in answering, but we have had days of rain with hurricane Harvey! Thank goodness it's stopped in our area now.
The modem did fix my problem. Thank you.
Hi prsmart,
No worries, thank you for your update. I'm so glad the rain has stopped in your area and the new modem helped! The community is here to help, so drop by if you need any more assistance.
I did not return the old modem because this message said it was not required. Now, I've received a message from Hughes saying they've not received the modem and will be billing my account if not received.
Thanks for the heads up, prsmart! I've manually received the modem in our system so it doesn't require any further action from you.
