System light blinking
I did not return the old modem because this message said it was not required. Now, I've received a message from Hughes saying they've not received the modem and will be billing my account if not received.
- Liz9 years agoModerator
Thanks for the heads up, prsmart! I've manually received the modem in our system so it doesn't require any further action from you.
