dzfire
8 years agoSophomore
System will not boot
System stopped working. Tried rebooting, power down, and reset. Only the power light and wireless lights come on. Checked all cabels.
- 8 years agoOver 12 years and HughesNet has taken care of me again. Thanks Amanda.
dzfire
Looks like I can access 192.168.42.1 through the LAN and access the wifi portion of the router. Still cannot access 192.168.0.1 on the LAN. Wifi connects but no internet.
- Amanda8 years agoModerator
Hi dzfire,
This is definitely odd - it could be that another gateway address is set on the device you are trying to use (192.168.1.1). Do you have any other devices you can test? Are all of your lights on the HughesNet modem lit or just a couple, like in your original post?
Thanks
- dzfire8 years agoSophomore
Only two lights are lit, power and wireless.
- GW8 years agoAdvanced Tutor
Try disconnecting the power and then the coax. Let it rest for a few. Reconnect coax and then the power. Maybe it will boot. This has worked many so many times for me I named this procedure the coax dance.
