System will not boot
- 8 years agoOver 12 years and HughesNet has taken care of me again. Thanks Amanda.
Hi dzfire,
This is definitely odd - it could be that another gateway address is set on the device you are trying to use (192.168.1.1). Do you have any other devices you can test? Are all of your lights on the HughesNet modem lit or just a couple, like in your original post?
Thanks
Only two lights are lit, power and wireless.
- GW8 years agoAdvanced Tutor
Try disconnecting the power and then the coax. Let it rest for a few. Reconnect coax and then the power. Maybe it will boot. This has worked many so many times for me I named this procedure the coax dance.
- dzfire8 years agoSophomore
Tried the disconnect last night ;) As a side note, I've been using HughesNet since the days of DirecWay out here and have been happy with it for the most part. Just gotta get back up and running so I can start work taody. :D
The new wifi modem doesn't get too hot but heat is another thing that used to shut me down. The 9000 was like a furnace. Sorry but that's about all I have for you. I hope Amanda can give you some help. No internet is very frustrating when there's work to do.
