Tech Realigned Satellite Dish, Still Experiencing Problems In FAP
Just for the sake of troubleshooting, do you have a device that you can connect directly to the modem via ethernet cable to see how it tests in comparison to the WiFi connected devices? I don't know that WiFi is the problem, but again, just for the sake of troubleshooting.
If you already mentioned that you tried something like this and I missed it, please disregard this reply.
I just went to test it with my laptop because this is a good suggestion and the problem persists even when connected with the cable that came with the new modem. It's the same laggy internet that tests 0.01. (I couldn't get it to load this for I could post from it or share directly, but it was similar to the speed test above)
hellovolchitsa wrote:I just went to test it with my laptop because this is a good suggestion and the problem persists even when connected with the cable that came with the new modem. It's the same laggy internet that tests 0.01. (I couldn't get it to load this for I could post from it or share directly, but it was similar to the speed test above)
That's unfortunate, though at least it rules it out.
I hope they can figure out what's wrong soon.
- Remy2 years agoModerator
hellovolchitsa,
Thank you for following up! I have sent a private message regarding your ongoing issues. Please let me know if you've received it!
Remy
- hellovolchitsa2 years agoSophomore
Token received and now here is where I am (ten minutes ago or so it would not load at all):
:::.. Download Speed Test Result Details ..:::
Download Connection Speed:: 45675 kbps or 45.7 Mbps
Download Speed Test Size:: 65.7 MB or 67229 kB or 68842721.28 bytes
Download Binary File Transfer Speed:: 5709 kB/s or 5.7 MB/s
Tested At:: https://TestMy.net
Validation:: https://testmy.net/db/34fMuFYYX
TiP Measurement Summary:: Min 39.82 Mbps | Middle Avg 46.42 Mbps | Max 56.05 Mbps | 27% Variance
Client Stats:: https://testmy.net/compID/45203551213701
Test Time:: 2023-10-19 12:13:40 Local Time
Client Location:: Galax, VA US https://testmy.net/city/galax_va
Target:: Dallas, TX https://dallas.testmy.net
Client Host:: Hughes Network Systems https://testmy.net/hoststats/hughes_network_syste
Compare:: 3% > client avg, 77% > host avg, 3% > city avg, 66% < country avg, 35% > world index
1MB Download in 0.18 Seconds - 1GB Download in ~3 Minutes
This test of exactly 65.65 MB took 12.067 seconds to complete
User Agent:: Mozilla/5.0 Windows NT 10.0; Win64; x64; rv:109.0 Gecko/20100101 Firefox/118.0 [!]
I have not gotten anything about a private message and not sure how to access to look unless I'm just moving too quickly- Remy2 years agoModerator
hellovolchitsa,
You are able to send me a private message here: https://community.hughesnet.com/t5/notes/composepage/note-to-user-id/102584
Remy
