Transmit / Uplink Problem
David,
Remy
David,
It normally takes between 1-3 days from what I've experienced, so expect it by Thursday! There should be instructions on how to get the modem up and going as well.
Remy
- Remy6 years agoModerator
David,
I would recommend trying out the new modem! It'll eliminate the old modem as a possibility, and hopefully end any experimenting we'd have to do with you.
Remy
- David_789336 years agoSophomoreI did install the new modem about two hours ago. No error codes since install completed. Packet loss has gone to 0% with the new modem, which is a good sign. And email is working somewhat more normally. So basic functionality is definitely improved. But speeds up & down are routinely horrible, currently averaging 1.1 Mbps up and 3.5 Mbps down. That may be at least partially the result of heavy usage mid-day in the time of COVID, but it's sure not close to advertised speeds of 3 & 25 Mbps. I will test again this evening to see what I get.
David,
Remy
