Good morning everyone,
Thank you,
Hi whysalives,
What an odd issue! I would like to bring this up with our network engineers to see what they can uncover. Just curious, do you have any success loading Amazon on a mobile app? Or have you tried loading Amazon.com on a different provider?
Thank you,
- Steveschmidt2019 years agoNew Poster
Same problem here! Even the mobile app on my android does the same thing as does the chrome and Samsung internets. My Toshiba laptop is having the same issue. Getting very frustrated!
- whysalives9 years agoSophomore
It does not load in safari on my ipad, but it does load in safari on my ipod touch. Both are using the wireless router in this case.
I have physically unplugged the modem, router, and the coaxil to the dish for over a minute with no change in results.
I would like to reiterate that bypassing the router also does not change the results.
That's curious.
Are you able to open a terminal and do a traceroute to amazon.com?
If so, could you do so and post a screenshot here?
Edit: Was also thinking what if you tried "rebooting" the devices you are having the problem on. Could be possible they're using a local DNS as well.
**CORRECTION**
It does not load properly on my ipod touch. It appeared to at first, but indeed it is having difficulty rendering pages.
Rebooting my laptop and tower was the first thing I tried in addition to rebooting the modem.
Here is a trace with the router, wirelessly from my laptop:
Here is a trace with a direct cable connection from the modem to my laptop:
