whysalives
9 years agoSophomore
I have bypassed my router with a direct cable connection to the modem, turned off web acceleration, reset the MBX, and have attempted rebooting the modem. The problem is across computers, users, and...
Good morning everyone,
Thank you,
9 years agoModerator
Hi whysalives,
What an odd issue! I would like to bring this up with our network engineers to see what they can uncover. Just curious, do you have any success loading Amazon on a mobile app? Or have you tried loading Amazon.com on a different provider?
Thank you,
Steveschmidt201
9 years agoNew Poster
Same problem here! Even the mobile app on my android does the same thing as does the chrome and Samsung internets. My Toshiba laptop is having the same issue. Getting very frustrated!
