Good morning everyone,
Thank you,
It does not load in safari on my ipad, but it does load in safari on my ipod touch. Both are using the wireless router in this case.
I have physically unplugged the modem, router, and the coaxil to the dish for over a minute with no change in results.
I would like to reiterate that bypassing the router also does not change the results.
That's curious.
Are you able to open a terminal and do a traceroute to amazon.com?
If so, could you do so and post a screenshot here?
Edit: Was also thinking what if you tried "rebooting" the devices you are having the problem on. Could be possible they're using a local DNS as well.
- whysalives9 years agoSophomore
**CORRECTION**
It does not load properly on my ipod touch. It appeared to at first, but indeed it is having difficulty rendering pages.
Rebooting my laptop and tower was the first thing I tried in addition to rebooting the modem.
Here is a trace with the router, wirelessly from my laptop:
Here is a trace with a direct cable connection from the modem to my laptop:
Okay, I decided to throw everything at it at once. I unplugged the modem, router, and dish. I shutdown and restarted the laptop. I connected the modem directly to the laptop and turned everything back on. I reset the MBX, turned off web acceleration, disabled windows anti virus and windows firewall for both public and private networks. I then cleared my cache and cookies and loaded amazon.com with control-shift for full refresh.
Viola! It worked.
I've turned the router back on, went back to wireless, turned on my anti virus and firewall, and turned web accelaration back on. Amazon.com is loading properly!
No idea what happened there.
For completeness, here is my current trace from my wireless laptop, now that everything is working:
Thank you for your help.
whysalives wrote:Here is a trace with a direct cable connection from the modem to my laptop:
For some reason that trace doesn't strike me as normal... Not used to seeing a lot of in-addr.arpa entries like that.
All that aside, it could have been anything really... Amazon, DNS, broken routing somewhere... No telling.- MarkJFine9 years agoProfessor
Yeah, almost looks like either qwest or most likely amazon.
Did notice that the IP resolved from 54.239.25.208 before complete reboot to 54.239.17.6 after, so could have also been the local DNS getting stuck on something weird.
Edit: Either way... looks like a team win.
