Using my data tokens BUT IT'S NOT showing how much I'm using - can anyone help?
I ran out of data and I still have a red circle, but it's not showing how much of the data tokens I have used and I have HAD to connect to my server for my website this morning and have been connected doing work there for more than 2 hours -- can anyone help so I'll know where I am with my data?
Your remaing token bytes are shown as 15.5 GB at the time you took the screenshot.
If you were to check later and it listed 15.4 GB you will have used .1 GB (100 MB) between those two points,
Example:
The MyAccount meter shows 37500 MB remaining (37.5 GB)
If I return later and it shows 37400, I will have used 100MB in the elapsed period.
- Gwalk900Honorary Alumnus
Example:
- happytexannSenior
THANK YOU!!!!!
Not that I'm glad you're in FAP, but thanks for posting the pic. I always wondered what the Usage Meter looked like when someone hit that point. :p
