happytexann
8 years agoSenior
Using my data tokens BUT IT'S NOT showing how much I'm using - can anyone help?
I ran out of data and I still have a red circle, but it's not showing how much of the data tokens I have used and I have HAD to connect to my server for my website this morning and have been connecte...
Your remaing token bytes are shown as 15.5 GB at the time you took the screenshot.
If you were to check later and it listed 15.4 GB you will have used .1 GB (100 MB) between those two points,
Example:
The MyAccount meter shows 37500 MB remaining (37.5 GB)
If I return later and it shows 37400, I will have used 100MB in the elapsed period.
Gwalk900
8 years agoHonorary Alumnus
Example:
happytexann
8 years agoSenior
THANK YOU!!!!!
