VPNFilter malware problem
The HT2000W modem isn't affected by VPNFilter. It's not susceptible to infection by this malware.
- Brucer467 years agoNew Poster
Who are you? Are you a Hughes tech? Cnet is now advising not only a reboot but a factory reset. This is a pain in the butt since you have to reconfigure your network but it is worth it if this really protects you. Are you confident in your advise and what are your qualifications? Thanks but I like to be carefull. BR
GabeU wrote:The HT2000W modem isn't affected by VPNFilter. It's not susceptible to infection by this malware.
This issue isn't so much the modem (actually the router) itself, but the network is behind a double NAT and the public IP isn't accessible from anyone outside of the HughesNet system. There's no way for anyone to get to it.
No, I am not a HughesNet tech, but I've been around long enough to know the ins and outs of this system and to know that the HT2000W is not susceptible. Mark has explained much of the reason why.
Secondly, the factory reset recommended by CNet is for commercial routers, NOT a HughesNet modem. If you perform a factory reset on the HT2000W modem you may end up doing more harm that good, and you would be responsible for the cost of the technician when one needs to be sent out to fix the issue the reset attempt caused.
