farmerhugh
9 years agoJunior
Wifi going down
For the last two weeks my internet goes down 1 or 2 times a day. The Hughes Net modem lights (the ones that are lite) are solid. When I reset the modem it comes back up. Is there any way you can c...
BirdDog
9 years agoAssistant Professor
Hi farmerhugh, have you checked to make sure it isn't something on the WiFi side timing out like the router or the adapter on the device? The first things to check when connection is dropping out. Thanks.
- 11 years ago
