Wifi going down
This should read "internet " going down. Not too sure I like this new format. We were having problems with the wifi a couple months ago after Amanda sent us a new router that problem went away, I don't see an edit button.
The EDIT button is the three little dots highlighted here in the righthand upper corner of the reply:
So by "internet going down" it still could be anywhere in the three break points I posted above. You will not have Internet access if there is a break in any of them.
When this happens can you access the Modems SCC?
What are the codes if any listed?
Do you know how to access the Modems State Code Monitor?
Again, when you have an issue the questions ... in order are:
Are all five of the front panel Modem LED's lit?
Can I see the first address along my cable path, the Router? (192.168.1.1)
Can I see the second address along my cable path, the Modem SCC (192.168.0.1)
Finally, is my Modem "seeing" the Gateway and Internet? (access remaining data info, access to a website)
- 11 years ago
