Wifi going down
this is what I get each time this happens--it resets--does this indicate that it is the router??
If you can't get to your router interface by going to 192.168.1.1 then either it may be misconfigured or having a hardware problem. What make and model of router? The default IP address may be set to 192.168.0.1 which will conflict with the Hughes modem.
We have to verify a couple of things.
Do you have HughesNet VOIP phone service?
Cable connections:
Note the following:
The Computer has one single output. It runs to one of the port on the rear of the router.
It is important that it is connected to one of the Routers four LAN ports, not the 5th somewhat off-set WAN port.
Verify that you are connected computer NIC> to router LAN> from Router WAN to Modem
- farmerhugh9 years agoJunior
I do not have voip from Hughes. (I am old and can't part with my landline lol)
I checked the cables. The only thing I had different was the computer wire was in outlet 2--I moved it to one as you indicated.
That wouldn't make a difference as long as it was plugged into one of the four LAN ports.
What brand of router do you have?
- 10 years ago
- 10 months ago
- 11 years ago
