emoji
emoji
  Back in the days before anyone had even heard of an emoji, regular characters were used to the same effect.
For example:  I used a ':', '>', ')', '>', to mean I'm smiling and I have a beard.  If I try to do the same thing here, the message editor changes the ':',  '>' to the emoji used by the editor, even when enclosed in quotes.  Is there a way to turn this off?
1 ACCEPTED SOLUTION
Accepted Solutions
Re: emoji
Testing  Smiley Embarassed)>.  I set emoticon to none in settings
8 REPLIES 8
Re: emoji
  Well, its been a week and no replies  I'm going to take that as a "no" .
Re: emoji
I'm old and remember those but still just looks like a bunch of scribbling and I don't want to take the time to look them up. That is why actual graphic emojis where invented.
Your question would most likely take forwarding to the website developers (third party). If you really want an answer probably should post in "Your Thoughts on the Community" or "Tech Support". The mods don't consider the General section as a place they are compelled to answer or take part in.
Re: emoji
  Yes, but none of them here have a beard.  Smiley Embarassed)>
  Thanks,  I didn't think of that.
Re: emoji
Re: emoji
ROFL!   Now just add longer than shoulder length hair, and make all the hair grey.  Smiley Embarassed)>
Re: emoji
That thing is crazy looking, isn't it?  Smiley Tongue
I tried to find one with real beard hair, but that's the best I could come up with.  I thought of creating one, but I'm not very good with editing and combining pictures like that.
Re: emoji
Well, that's a good start.  I guess I'm going to have to learn to use GIMP.
Re: emoji
