Solved! Go to Solution.
Unless things have changed since it was last updated, the difference can be significant.
All Gen5 plans have a universal FAP policy, where the speed during FAP is reduced to "as low or lower than 1Mbps". Some see speeds up to 3Mbps, but there is no guarantee with this.
With Gen4 it works differently, depending on whether the plan includes "Smart Browsing". Those with "Smart Browsing" enabled plans will still be able to do most non data intensive things without much noticeable difference: i.e. browsing, email, shopping, paying bills, etc. However, large file downloads/uploads or other data intensive things will reduce the speed. Plans without "Smart Browsing" will see their speeds reduced to approximately 150Kbps, regardless of activity.
https://legal.hughesnet.com/FairAccessPolicyGen5.cfm
https://legal.hughesnet.com/FairAccessPolicyGen4.cfm
I don't think so. When you're in FAP, your speeds are up to 3 Mbps.
ETA: I hope someone will correct me if I'm wrong.... Mods?
Cheers, Gabe!
