- BirdDogAssistant ProfessorHit or miss, more often miss due to latency on satellite.
- thats what i was afraid of...lots of money for something that may not work
- what about netflix...seems hit or miss with it as well
- BirdDogAssistant ProfessorNetflix works but there is the data limit. No HD, but SD or low definition can be done without eating through excessive amounts of data. Again, still a limit depending on plan amount, can't expect satellite internet to replace cable TV or satellite TV. Low definition Netflix uses about 300 MB per hour, SD about 700 MB per hour.
- i have directtv but have some shows i like to rewatch..ie sons of anarchy and it will do great for about 20 min or so then lose connection
- BirdDogAssistant ProfessorConnecting the DirecTV box to your HughesNet is not advisable, it will eat lots of data in the background and pausing/time shifting will also use more data.
The best way to do Netflix from my experience is using the browser on a computer connected to the TV using HDMI. - El Dorado NetwoAdvanced TutorOne of our customers tried using an AT&T cell-over-Internet box (AKA a "FemtoCell") and it didn't work.
- AmandaModeratorHello tvignoe,
Glad to see our Champs were able to drop in and answer your questions. Feel free to post back if we missed anything or you need more assistance.
Thank you
Amanda - Any feedback from other customers regarding the feasibility of using AT&T's MicroCell (yet another cellular extender over internet device)? Here's a link for more info: http://www.att.com/att/microcell/
Would be nice to not have to secure another account for a land-line service. - GabeUDistinguished Professor IV
-rs,
I don't have any experience with the product, but from what it says on the link you gave, I wouldn't count on it working. It mentions the incompatibility with satellite service.
- 11 years ago
- 12 months ago
